Restoration & Repair Tips Board
testing electrical gauges
1031D
07-07-2006 21:27:06
How do you test an electrial gauge when it is off the machine? Is there some sort of an Ohm test?
Joe (Wa)
07-10-2006 09:31:04
 Re: testing electrical gauges in reply to 1031D, 07-07-2006 21:27:06
Most older electrical gauges can be ballpark bench tested.
Some basic tests at the link.
John T
07-08-2006 06:23:25
1031, I agree with all of Bob's good advice, heres a lil more info for ya. As far as any ohms check, although they have different ratings, if an ohmmeter across it shows an OPEN circuit its indeed bad, it has to have a continuous current path through it to the sender to ground to work n deflect the needle.
I DO NOT recommend this but knew this dude (who was that guy and would do such a thuing lol) who would sort of crudely bench test them by ataching a hot battery lead wire to one terminal and then very briefly scratch/rub/touch/bump a wire from the other terminal to the other gauge terminal to see if the needle jumped over. It would be wise to have a current limiting resistor on one lead to prevent overcurrenting the gauge and popping/blowing it out, but as Bob pointed out one would need to know the senders ohms rating to run this test properly.
To work a gauge must have continuity through it and then its innards be okay so the needle deflects according to how much current flows through it. Typical problems may be internal corrosion has the needle stuck or else its windings have simply opened which the ohmmeter test would indicate.
John T
Bob
07-08-2006 01:01:33
Oil pressure, fuel, and temperature gauges?
Each brand has their own range of sensor Ohm values to move the gauge though it's range.
If you have a service manual for the equipment the gauge was used on, it may give those values.
Also, some gauges are designed for 6-Volts, some for 12-Volts, and so on, and some guages are feed from an IVR... (Instrument Voltage Regulator) that chops the incoming battery voltage at a slow rate, to provide a regulated average voltage to the gauges.
So, yes they can be bench tested, but you need to know the supply voltage and the sensor values.
