Charlynn Hydraulic Valve
Frmldon
03-11-2002 19:07:28
An older tractor I am restoring, has a Charlynn hydraulic valve. The valve has two working ports, but only seems to operate one way (the tractor has live hydraulics). Is there a way to tell if this valve is a one-way valve, or if the valve is simply worn out? Thanks for your help.
comercilizadora intertrac
09-06-2005 16:07:22
 Re: Charlynn Hydraulic Valve in reply to Frmldon, 03-11-2002 19:07:28
good morning we are comercializadora intertractor ltda, company located in cali colombia and in which we sell parts for machinery. we want that to quote a hydraulic motor marks char-lynn it indexes: 01105-112-1068-006 type: high torque flow: 11 gallons per minute pressure: 2000 psi displacement of the motor:27 inches cubicas/revolucion torque: 8650 pound for inch speed: 84 revolutions per minute we wait their answer attn RAÚL MÉNDEZ R COMERCIALIZADORA INTERTRACTOR LTDA TELEPHONE 011 572 8890909 FAX:011 572 8890094 email intertractor@hotmail.com
Rubén Gaete A.
11-05-2004 06:18:48
Can you help us, we need to quote charlyn Valve, we have the p/N J970418-6041091002XA.
Thanks in advance for your coperation
RUBEN
Brian
04-02-2002 21:09:46
I also have a tractor with a charlyne lifter/loader. I was blown away to walk into a local part store and find the exact same valve on the shelf. The valve was made by a company called Gresen. If you go to WWW.princessauto.com, click on "download catalogue" and then chose hydraulics you will find a selection of these gresen valves.
To answer your question. If the valve has 3 ports they will be inlet, port A, and exhaust or outlet. These are "3 way" valves used on single acting cylinders. If the valve has 4 ports, inlet, port A, Port B and outlet, it is a "4 way" valve and can be used to control double acting cylinders.
Hope that helps.
Oh btw... the gresen valve in Canadian dollars is 150.00 which is about 100 us. Good deal for you.
Jerry S
03-13-2002 06:33:38
As recently as 10 years ago, I bought a new part from these guys who had a distributor place in town. Maybe you could find a part number and a way to contact them to see just what they can tell you.
Jake
03-12-2002 20:50:02
You didn't say what the valve is being used for. If it's for a loader with single action pressure would lift the loader and when lowering the arms fluid would flow back in the same hose. a single acting valve should have one working port and the double acting would have 2 [these are in line with the control spool]
