Restoration & Repair Tips Board
Case 220 over heats
Sassafras Jane
07-15-2006 10:28:07
I have a Case 220 lawn tractor. It over heats, like turning the exhaust red. What could cause this. I have adjusted the idle and fuel mixture per manuals instructions and checked the air filter. I'm not a mechanic exactly but I do basic repairs. No idea of cause. HELP!
I purchased this mower to use but it has become a hobby!
old
07-15-2006 11:43:06
 Re: Case 220 over heats in reply to Sassafras Jane, 07-15-2006 10:28:07
What type of engine does it have?? Sounds like the timeing is off, or its running way to lean either one will casue that problem
Sassafras Jane
07-15-2006 17:20:05
 Re: Case 220 over heats in reply to old, 07-15-2006 11:43:06
It reads:
Kohler the cast iron line 10HP
the tractor has the words:
Case 220 hydralic drive
old
07-15-2006 18:31:39
 Re: Case 220 over heats in reply to Sassafras Jane, 07-15-2006 17:20:05
Yep carbs probably set to lean on most of the engines like that theres not much if any way to adjust timing unless the flywheel key is bad and if thats so you need to replace the key
Bob
07-15-2006 22:08:48
 Re: Case 220 over heats in reply to old, 07-15-2006 18:31:39
You set the timing by varying the breaker point gap, while using a timing light. On these engines, the flywheel key has NOTHING to do with spark timing. Here's a link to the service manual, with detailed instructions. You have a K-241, look up the "spec's" accordingly.
wgm
07-26-2006 16:42:36
 Re: Case 220 over heats in reply to Bob, 07-15-2006 22:08:48
Bob's procedure is right on. Easy to do.
