Restoration & Repair Tips Board
1956 300 Utility Tractor
Eric Buls
07-26-2006 19:23:53
My father has had this tractor for the past 30 years. It been a great tractor. The only problem he has had is there is a seal between the hyd. system and the engine oil compartment that blows sometimes when you lift an excess amount of weight with the bucket.Then the oil compartment fills with hyd. oil. He has had this replaced 3 or 4 times in the past. He gave the tractor to me and now I have the same problem. I would like to know where this seal is located so I can fix it myself. thank you. Eric
