Restoration & Repair Tips Board
Light does not work-Ideas?
DCM
07-27-2006 05:58:12
I was trying to get the license plate light to work on my 1969 car,there is power to the socket but the bulb(several bulbs) do not light up unless I actually ground the socket that holds the bulb,its all clean in there, on its own the bulb will not light up,cleaned off the bracket that holds the pigtail but does not help.Hope I explained my problem ok.Any thoughts? Thanks,Dan in AB
old
07-27-2006 08:46:10
 Re: Light does not work-Ideas? in reply to DCM, 07-27-2006 05:58:12
Well you sort of answer the question your self when you said if you ground the socket. Your problem is where ever it goes its not grounded. If its in the bumper like a good many are the bumper mount on the car is probably so rusty that its no longer grounded . You can run a ground wire right to the socket and fix it or you can clean up all places that thing bolt on amd fix the problem but the wire will be easier to do
DCM
07-27-2006 11:57:42
 Re: Light does not work-Ideas? in reply to old, 07-27-2006 08:46:10
Howdy old,I did not consider the bumper not being grounded, I think I know what to do.Thanks Dan
old
07-27-2006 12:22:32
 Re: Light does not work-Ideas? in reply to DCM, 07-27-2006 11:57:42
Gounrds on old cars be be fun ti figure out. I know I usto work on cars but now because of my bad back I no longer can so I switched to working on tractors
RustyFarmall
07-30-2006 08:15:44
 Re: Light does not work-Ideas? in reply to old, 07-27-2006 12:22:32
I have even soldered a ground wire directly to the bulb socket, and then fastened that wire directly to the frame. Used the same trick on tailights that worked, but just weren't as bright as I thought they should be. That extra ground wire will really brighten things up.
