Restoration & Repair Tips Board
JD B, smoke
dennis stampe
07-30-2006 07:09:24
suddenly lots of smoke from the chimney; was running well; what gives?
old
07-30-2006 10:01:18
 Re: JD B, smoke in reply to dennis stampe, 07-30-2006 07:09:24
If its black smoke and it just started all at once you most likey have some junk in the carb or the float is going bad and has a hole. Or if it sat for say a month you might have dirt dobbers in the air cleaner
John T
07-30-2006 08:41:03
Is it Blue (oil) or Black (Excess gas/inlet air restriction)???? You may wanna remove the air cleaners lower bowl n see if its full of water or all clogged up or overfilled. If its black smoke you may wanna insure the choke butterfly plate is open n stays open and for restrictions in the air cleaner or inlet piping including the air cleaner bowl as mentioned above. If black have the carbs needle adjustments got moved?? Is it still running on BOTH cylinders??? as that can cause smoke n real poor running.
John T
