Restoration & Repair Tips Board
856 PTO not working
Curly G
07-30-2006 09:32:37
The pto stopped working while cutting hay. PTO shaft seemed to be very warm when unhooking the haybine. Does not seem to be in the valve, oil pump? clutches?
Bob
07-30-2006 09:38:58
 Re: 856 PTO not working in reply to Curly G, 07-30-2006 09:32:37
If it quit suddenly, you MAY be in luck for a cheap fix. There is a little pin inserted crosswise to hold the upper and lower parts of the control valve together that shears, and the PTO will no longer engage.
You have to remove the PTO control valve, and, IIRC (it's been a while), the plug beneath it, to get all the parts out, to put them back together.
Engage presure should be checked afterwards. You need to get an I&T manual for more details.
