Restoration & Repair Tips Board
8N gear replacement
Rod Spivey
08-01-2006 05:29:05
I have an 8N model and serial 472138 and need to replace the 2nd gear. I was wondering if there is any guide or video that might give me instructions on how to go about the task. I am rebuilding the engine also and have found both for that task. Any advise will be greatly appreciated.
Thanks, Rod
old art
09-04-2006 20:03:45
 Re: 8N gear replacement in reply to Rod Spivey, 08-01-2006 05:29:05
that transmision has tapered bearings when yopu take it apart you have to be sure to set the preload on the bearings there are shims on the rear bearing retainers the bearings may be worn so they let the shaft move up and down not good for gears . do it right the first time. not a hard one to fix
Dan
08-04-2006 13:09:18
Get an I&T service manual for the 8N Ford tractor. It goes over this proceedure step by step with pictures. You can get this manual off this site, Tractor Supply stores, or several other online parts suppliers.
Good luck,
Dan
