Restoration & Repair Tips Board
D7H Engine Problem
Ernest Boateng-
08-08-2006 16:13:59
Dear All,
I am experiencing frequent water hose bursts due to pressure built up form. We have cleaned the radiator and the oil cooler but the problem persists.
Could anyone assist me to identify the problem and offer any assistance to the repairs.
Ernest.
OlChief
08-13-2006 15:38:42
 Re: D7H Engine Problem in reply to Ernest Boateng-Okrah, 08-08-2006 16:13:59
I have had this sort of problem due to porous CI cyl.liners.To locate the bad liner,I removed all injectors and valve rockers.Made the necessary adapters and high pressure tubing fitted with a HP gauge and connected to a nitrogen cylinder.Then one by one introduuced the nitrogen into each cylinder thru ihe injector port, watching for bubbles in cooling system and or unusual pressure loss.I was careful not to excede the nornal compression pressure.Nitrogen was used in order to prevent a diesel explosion,although CO2 could have served as well.By this method you may at least find the leaking cylinder be it liner, gasket or head.DO NOT USE OXYGEN period.In My case All heads had been removed and tested -OK.What was found was a leaking liner even though internal visual inspection reveiled nothing while the heads were off.The liner was porous enough to allow compression to pass thru to the coolant side of the engine.
the tractor vet
08-08-2006 20:03:56
Could be a cracked head or bad precups or liners leaking comp. into the cooling system. Nothing money won't fix.
