Restoration & Repair Tips Board
Briggs 16 Twin II problem
bford
08-11-2006 12:25:48
I'm having a problem with my 15 year old motor, a Briggs & Stratton 16 horse Twin II. It seems to run really hot after 10 minutes or so, and loses power. I changed the oil, didn't smell gassy. Is there something that would cause oil to not get to the cyliders? I pulled off the tin covers, there's no grass or anything blocking the air.
Oldmax
10-30-2006 04:37:19
 Re: Briggs 16 Twin II problem in reply to bford, 08-11-2006 12:25:48
After you check all the things on the list check the Crank shaft Key on the flywheel if it is halfway sheared the engine will still run but will run HOT had this to happen on 1 1/2 HP engine . on Roper mower I had a few years back it about drove me up wall trying to find trouble .My uncle is still using it is 84 model .
Oliver in SC
08-20-2006 10:18:25
Things to check: Clogged muffler? Fuel mixture screw adjusted correctly? Anything wrapped around the lower crankshaft? If it's a mower, are the blades spinning freely?
joseph brasfield
08-11-2006 13:44:46
i think this engine has an oil pump or slinger not really sure right now but will get back to you as soon as possible joe
