Cracked Block
Greg Hunter
10-21-2001 18:59:09
I have a Case 310 Diesel crawler/loader that has a crack along the outside of the left side of the block. No antifreeze seems to get into the oil, but it dribbles out on the outside. I have patched it with JB-Weld, but after a couple of starts it opens back up and leaks again. Are there any easy solutions any body can recommend?
skipjack
01-10-2002 19:12:56
 Re: Cracked Block in reply to Greg Hunter, 10-21-2001 18:59:09
I've sealed cracks in blocks for years with sodium silicate (aka: waterglass) and they seem to last forever. The last one on a VAO Case was done 5 or 6 years ago in a crack on side of block about 4 in. long and no antifreeze has needed to be added to this date. The crack area is as dry as a bone. Red Devil brand "Thermoseal- High temperature stove and gasket adhesive" IS sodium silicate and I used about 3 oz. to seal the VAO. Just fill the radiator and block with water, add the waterglasss and run the engine until the crack seals. Then drain 1/2 the water and add antifreeze. It will seal cracks that commercial stop leak products don't even slow down. Your hardware or stove store should have the Themoseal for 3 or 4 bucks for 3 oz bottle.
Chums5
10-22-2001 18:01:12
Greg.....I've had good luck with two methods....welding for the big cracks but I use tempered brass rod..when done it moves with the block(expand & contract) and don't recrack..!!..and the other method is to make a patch..... for small cracks that don't leak much...to make..take a pc. of steel twice the size of the crack...drill holes in pc.(like in 4 corners)and mount to block..drilling and tapping holes in block..mount plate with rubber gasket and lots of gasket sealant...(this only works if crack is in the flat of the block)....hope this helps alittle....good luck....
Bill(Tx)
10-22-2001 16:13:07
The permanent solution would be to repair it with inserts. It is usually done while the engine is in teardown, bare block.
BillD
10-22-2001 06:02:11
Check the archives for crack repair by drilling and pinning.
