Restoration & Repair Tips Board
towing a tractor on highway.
ED NEUBAUER
08-20-2006 14:02:46
I know this might sound stupid ? I am trying to find out if anyone has towed a tractor on one of those car dollys, tractor wheels on the dolly and front tractor wheels on the road it looks like it would fit ok possible some minor modifications,the one I looked at was rated at 3500 lbs, I have 53 ford jubille, everyone I talk to looks at me real strange,I guess the beard and being over 60 has something to do with that,I have not talked to the dolly rep. yet fast EDDIE, THANKS GUYS AND GALS
Dennis'640
08-25-2006 10:28:14
 Re: towing a tractor on highway. in reply to ED NEUBAUER , 08-20-2006 14:02:46
My 2 cents. I hauled a 640 from northern Michigan to just south of Detroit. I rented a double axle car trailer from U-Haul. I wouldn't take a chance because trailer rental is cheep.
Bob M
08-22-2006 08:41:08
I agree with John's comments below - consider a dolly only for low speed/short distance movements!
Tractor tires are simply not designed for high speed operation. (I recently purchased a new set of Firestone tractor front tires - the sidewalls are clearly marked "25 MPH MAXIMUM SPEED".)
Another reason to keep the towing speeds low if using a dolly: Tractors have no suspension. At higher speeds any kind of a bump is gonna bounce the tractor tires clear of the road which could cause vehicle control issues - especially if you are negotiating a bend in the road. Also the repeated impact will beat h*ll out of delicate parts like the carb, radiator, battery, etc.
So unless you're towing short distances over back roads spend a few $ more and rent a trailer for your "53 Ford".
john in la
08-20-2006 23:20:19
I pulled my Ford 861 with a 5' brush cutter about 500 miles with a car trailer I rented at U-Haul. This is a much better option than the car dolly. You just need to tell the people at U-haul you will be pulling a 53 ford and forget to mention it is a tractor. If they insist on a model tell them you do not really know because this is a friends car.
The problem with a dolly is the fact that the tractor tires; king pins; and steering linkage will not stand up to highway speeds. You may be OK for a short distance at 20 to 25 MPH but you could drive the tractor itself that fast.
Bob
08-20-2006 22:59:08
Besides the obvious liability issues, if something goes wrong, SOME tractors cannot be towed any distance at any speed because the upper shaft of the transmission does not get properly oiled unless the engine is running.
That being said, this caution MAY not apply to a JUB (I can't recall just how the tranny is set up), yet it's something to consider, and certainly could be an issue for some folks reading this, and getting the idea to try to tow another brand of tractor.
85_Ranger4x4
08-20-2006 20:40:52
Dollies work just fine, just don't go too fast. I would say 25 mph tops, we have done it a couple times at it works great as long as you take the side roads.
KEB
08-20-2006 19:21:13
If you're going to rent a dolly, why not just rent a car hauler & not have to worry about it. That ford should fit nicely on a car hauler or flatbed.
I'd also be concerned about the front tractor tires not being rated for highway speeds. Would hate to have one come apart while I was going down the road. You'd also have to lock the steering to keep the tractor from swinging from side to side. I don't think the tractor front end would have enough caster to track well, particularly with the rear end higher than the front.
At first glance, a dolly looks like a really bad idea. Would have to think very carefully before doing something like that, particularly when you compare the risk with the cost of renting a trailer for the day.
Keith
dust
08-22-2006 10:17:20
 Re: towing a tractor on highway. in reply to KEB, 08-20-2006 19:21:13
why not put the tractor in the bed of your truck. thats how I brought mine home when I bought it. If it"s a 8ft box it will fit in there fine.
