Restoration & Repair Tips Board
172 CID Engine rebuild ????
RK
08-22-2006 17:30:22
I have 1964 Ford 4000 with a 172 CID gas engine that is tired. Smokes a lot. Can I pull the oil pan and head then the rod ends off and slide the pistons out the top? Hone.... new pistons, rings, and bearing all without a major breakdown of the tractor?? Thanks!!
RK
showcrop
09-12-2006 18:12:17
 Re: 172 CID Engine rebuild ???? in reply to RK, 08-22-2006 17:30:22
yes you can! butget complete sleeve kits, because yours will have taper and get Lockite sleeve sealer to "glue" them in enjoy!
RK
09-12-2006 18:32:09
 Re: 172 CID Engine rebuild ???? in reply to showcrop, 09-12-2006 18:12:17
Thanks showcrop. I just finished today. My older version 172 did not have sleeves so I just did new pistons, rings, and all bearings. Honed the cylinders. I did have .007 taper but will live with it. All in all it was not way out of spec. I do wish I could have found .001 undesize bearings as I currently have .003 clearance so not the greatest oil pressure. I had to go with stock size. .010 replacements that most places stock would have meant a complete tear done and machine shop. I did rebuild the roto oil pump. I see they make a 100 lbs version. Not sure if I need to bother. It"s 25 lbs at idle hot. Rocker arms are nice and wet. I was hoping for more like 40 lbs though. However... she runs sweet! No more blow by or buring oil! YEE HAA
RK
