Restoration & Repair Tips Board
REAR RIMS
FAST EDDIE
08-23-2006 18:11:04
Recently purchased 53 ford jubilee for hobby farm and to restore and go to tractor shows, rear tires have calcium water, rust is showing up on one rim on the outside and I can see minor water coming through small rust spots and a little coming through the tires, I AM thinking about pulling tires off , try to clean up inside and outside, paint, new tubes, forget the water, and try to find wheel weights if available, if rims are to rusty can they be repaired ? THANKS
Tony in IN
08-29-2006 09:40:42
 Re: REAR RIMS in reply to FAST EDDIE, 08-23-2006 18:11:04
I can't offer much advise on the repair process, I'm in the middle of that myself but I did find out that there is a product available that is supposed to weigh as much as the calcium chloride but not have the nasty side effects. It's called Rimguard but may not be available in all areas, as I've been told by others who have tried to get it. Price is not supposed to be much more than CaCl but cost is relative, I guess.
Tony in IN
souNdguy
08-24-2006 04:51:59
If the rims are structurally sound.. but just havesome pitting and a few rust holes, yes.. they usually can be repaired. Wire wheel or sand or flap disc down to bare metal on all spots. Rust holes can be brazed or welded. Usually the valve stem hole is rusted out. Fix is to either braze or weld up and drill a new hole somewhere else.. or fint an appropriate sized flat fender washer, tap it into contour, and weld in place as a patch, then grind down profile a bit.
Ket here is to get rid of anything that will abraid or poke a tube.
After weld/braze repair.. file / grind all welds to get rid of sharp points.. prime and paint. I'd use a rusty metal primer. I have used spray cans of 'appliance' epoxy paint to paint them afterwards. It makes a great durable coat over a good rust control primer.
Soundguy
