Restoration & Repair Tips Board
Distillate Carb on a Gas IH A
Lash Larue
08-26-2006 05:01:45
My '41 A has a Mdl 161 Zenith distillate/gas carb. I identified in a couple of books I have and the manual. The tractor runs good but discharges sooty black smoke out the muffler. The idle screw is almost bottomed out in the closed position, per the manual and the main valve on the bottom of the carb is closed tight. Can someone give me any ideas what is wrong or how to correct the problem. I have a contact locally who deals almost exclusively in old tractor parts and I can get a kit but if it is and adjustment problem I want to go that route as the tractor needs new rear wheel bearings so I want to keep it running until I can afford the bearings.
CNKS
08-26-2006 08:22:31
 Re: Distillate Carb on a Gas IH A in reply to Lash Larue, 08-26-2006 05:01:45
You have answered your own question, it is running too rich. Disassemble, soak in carb cleaner, blow out with compressed air, set the float to specs, put in a carb kit. Not much to those carbs. Best kits are from Case-IH, will cost more than after market.
