Restoration & Repair Tips Board
B-275 bolt tightening pattern and ft/lbs required
Jan Larsson
08-30-2006 00:14:12
I`m been restoring my tractor and i need to know the bolt tightening pattern and ft/lbs required for the cylinder head.
I´m thankfull for all tips, this tractor is not that common here in Sweden so any help is great.
jdemaris
09-04-2006 10:59:35
 Re: B-275 bolt tightening pattern and ft/lbs requ in reply to Jan Larsson, 08-30-2006 00:14:12
B-275 with the diesel engine (BD144) has head bolts torqued to 70-75 ft. lbs. and rod bolts 30 - 35 ft. lbs. Tightening pattern is from the middle two inside bolts out. Be careful if trying to chase or clean up any threads in the block because the tapped holes for all the head bolts are Heli-coiled.
