Farmall M fan Belt
Ray
03-15-2002 06:05:54
I need some inf. on replacing the fan and generator belt on a farmall model M. I know the pulley is split, however, I can't figure out how to adjust it. There is a set screw on the side of the pulley and bolts on the front of the fan. Do they need to be removed? Can someone tell me exactly how to replace and adjust the belts. -Ray
CNKS
03-15-2002 18:02:53
 Re: Farmall M fan Belt in reply to Ray, 03-15-2002 06:05:54
You don't need to remove the bolts. Loosen the set screw and loosen the part of the pulley that the set screw is in counter clockwise. If tight carefully tap it. It is cast and can break. You may need to use pentrating oil. Others may have other ideas. The one on my M was easy to move last time I changed the belt.
