Restoration & Repair Tips Board
Refinishing Rear wheels on 1940 9N Tractor.
David Maryott
09-24-2006 09:45:43
Is it safe to remove the six large bolts from the rear wheel hub, (hub from the wheel rim)without letting out the air first? Will it warp the wheel?
I know the pressure is low.
I need to clean and repaint both rim and hub.
Thanks.
old
09-24-2006 12:32:27
 Re: Refinishing Rear wheels on 1940 9N Tractor. in reply to David Maryott Sr., 09-24-2006 09:45:43
Yep it will not hurt any thing to do that as long as its on a jack etc. But figured you knew it has to be jacked up
