3-point hitch will not work
dave
03-17-2002 15:21:15
My dad has a Satoh tractor and the 3 point hitch will not lift.I can lift it easily by hand but it falls back down.It has plenty of fluid and the hydraulic pump in the front is working and has alot of pressure at the line coming off of it.Anyone have any advice?
gordon tidd
06-14-2005 12:39:23
 Re: 3-point hitch will not work in reply to dave, 03-17-2002 15:21:15
the 3 point hitch gose all the way up or all the way down. there is no stoping it half way.
Green_in _MI
03-23-2002 12:35:47
On some tractors the 3pt will not lift if you connect hydraulic hoses to the pump. On older Deere tractors you have to change plugs that will divert the flow internally from the 3pt to the hoses. Don't know anything about Satohs but that is often why Deere 3pts don't work.
dave
03-23-2002 16:33:59
 Re: Re: 3-point hitch will not work in reply to Green_in _MI, 03-23-2002 12:35:47
Thanks Green in MI for the info. This pump has not had any extra hoses hooked up to it. But if you find any other info please pass along. THANKS
steve
03-23-2002 19:04:27
 Re: Re: Re: 3-point hitch will not work in reply to dave, 03-23-2002 16:33:59
dont know this tractor, but our AC had an internal cylinder that pushes a cross rod, lifting both 3 point arms. the internal cylinder had its hose blown and the oil was running back to the steering/ hydraulic compartment. can you see the cylinder, or internal? our AC had a rear cover over the PTO that was easlily removed for back end inspection, hose replacement.
dave
04-02-2002 19:51:44
 Re: Re: Re: Re: 3-point hitch will not work in reply to steve, 03-23-2002 19:04:27
Steve, This tractor does have an inspection cover under the seat, I removed it and could see the internal cylinder but no hoses connected to it. On the side of the trans.there is a valve body which the control lever attaches.A friend told me maybe one of the valves inside it might be stuck open or closed so I will try that next. Thanks again for your help. Hope this is it.
dave
03-24-2002 16:32:26
Steve, Thanks for the info. This week I will look for an inspection plate and see if I can see the cylinder or hoses. Thanks
dave
04-15-2002 18:17:53
 Re: Re: Re: Re: Re: 3-point hitch will not work in reply to dave, 03-24-2002 16:32:26
Steve and Green in MI, I took the valve body apart and found a piece of metal stuck under a check valve.The valve was stuck open.After removing it, it works great. THANKS for the help.
