Restoration & Repair Tips Board
mastercraft riding lawn mower
caddy
10-06-2006 03:46:33
i have a sears riding lawn tractor (mastercraft)that has a 12hp briggs with a 38"deck,its 7yrs old and the model # sticker is no longer there,i could use a manual to help me order new parts, or if someone knows how i can identify the model,it runs great ,but throws the drive belt to the rear axel off,when on uneven ground sometimes . it has a vertical drive out put shaft on the bottom side of motor. can any body please help identify the model.e-mail kadulop@hotmail.com
rustyj14
10-30-2006 17:35:50
 Re: mastercraft riding lawn mower in reply to caddy, 10-06-2006 03:46:33
Check the condition of yer belt. If it has worn edges, or frayed sides, material hanging off it, it might need replacing. Mastercraft did not make Sears Craftsman tractors, as far as i know. check also the condition of the rear pulley and any idler pulleys, for looseness of the bearings, or the mounting hole in it, or wear! If you need a new belt, don't buy it at the local hardware store--go to a lawn mower repair shop to buy the belt. they will probably have an assortment so they can sell you the correct type of belt!
135 Fan
10-21-2006 03:00:53
A craftsman is made by a different company than mastercraft. A mastercraft is probably made by MTD. Don't know the model though. Dave
