Restoration & Repair Tips Board
460 gas stalling out
Bruce Nething
10-12-2006 09:23:20
I have a 460 gas with new points, plugs, coil,condenser, and distributer cap. It starts up just fine, but after running it for 45 min.-one hour, it diesout. It almost sounds as if it is flooding out. The carburetor has been rebuilt and appears fine. But like I said, after warming up real good, or making the tractor exert some effort, it dies. Any suggestions are much appreciated. Thanks. Bruce
Ol Chief
10-21-2006 18:38:03
 Re: 460 gas stalling out in reply to Bruce Nething, 10-12-2006 09:23:20
I had the similar problem with my 460 and it drove me nuts. Finally I found that the air cleaner was practically choked with dirt.
CNKS
10-12-2006 17:42:45
When a weak coil gets hot it will cause that problem. If that is the case, it should start in a few minutes, then die sooner the second time. When it dies check the spark, I doubt if there is any.
CNKS
10-12-2006 17:49:35
 Re: 460 gas stalling out in reply to CNKS, 10-12-2006 17:42:45
Missed that you replaced the coil -- Could be a fuel flow problem, but that usually occurs within a few minutes. I still suspect the ignition. 460 has a 12 volt battery and generator; along with a 6 volt coil running through a ballast resistor, you might check that out.
Bruce Nething
10-13-2006 08:33:31
 Re: 460 gas stalling out in reply to CNKS, 10-12-2006 17:49:35
Thanks for the advice. I'll check out both ideas.
old
10-12-2006 13:17:45
When it dies on you do you still have a good brite blue spark?? If not then you have a problem in the ignition. Also when you replaced all the other stuff why didn't you replace the rotor?? Shoot even a bad rotor could be your problem.
Bruce Nething
10-13-2006 08:39:20
 Re: 460 gas stalling out in reply to old, 10-12-2006 13:17:45
I"ll look into that also. Thank you.
