Restoration & Repair Tips Board
JD 2020 serial and/or engine number
motorhead
10-14-2006 18:59:32
I just purchased a JD 2020 with the diesel engine. Seems like it will need engine work possible overhual, however I need to locate the serial number and/or engine number so I can start locating parts, can anyone help?
farmall100
10-17-2006 07:57:56
 Re: JD 2020 serial and/or engine number in reply to motorhead, 10-14-2006 18:59:32
the serial number is on the right side of tractor(as you are in seat)down almost below the seat on the side of transmission housing. its kind of hard to read the number without a mirror . there should be a plate riveted there with your numbers. the engine serial number is on the same side (right) but between the starter and oil filter. use the tractor serail numer for reference with parts. mother deere has a parts web site with exploded diagrams of the tractor with part numbers listed. I go there and find out the part number before i buy to make sure that i get the right part. I have a 69 2020 diesel.
