Restoration & Repair Tips Board
1950 John Deere A
Jackie Bieghler
10-15-2006 17:37:53
How do you remove the clutch (belt pulley) from the gear drive shaft? I need to replace an "operating bolt", but I can't remove the pulley. I have removed all adjusting, lined, and drive disks but now I'm stuck. Also, any recommendations on where I can purchase an "operating bolt"?
Bob 49 A
10-23-2006 15:00:46
 Re: 1950 John Deere A in reply to Jackie Bieghler, 10-15-2006 17:37:53
the bolts are still available from John Deere Dealer. I just got some. But they are not cheap.
B-maniac
10-19-2006 10:52:49
What you need to get is called" Service Manual For John Deere Dealers". It is a reprint of the original.It comes in loose leaf to be put in a ringed notebook.It is not cheap.I paid around $70 for mine.Can't remember where I sent to get it but I'm sure if you ask on the JD forum,someone will tell you.In the mean time,I will try to look up where I got it. It tells/shows 10 times the detail that the others do.It's well worth the money. When I find where I got it I will post you on the JD site.
Jackie Bieghler
10-17-2006 18:56:31
I do own both the Operator's Manual (OMR2002CC) and the I&T Shop Service Shop Manual for the tractor. I used both as I dis-
assembled the clutch disks. Neither manual gives me the answer regarding the actual removal steps to remove the clutch pulley.
CalJim
10-15-2006 21:50:00
Hello,
What,may I ask,is an "operating bolt"?
Do you have a service manual or parts book?
You should have a manual when it goes back
together so you can adjust the clutch properly. CalJim
Jackie Bieghler
10-17-2006 19:04:58
 Re: 1950 John Deere A in reply to CalJim, 10-15-2006 21:50:00
The I&T Shop Manual that I purchased after I bought the tractor shows an "exploded view" of the clutch assembly and it calls these (3) bolts as "operating bolts".
greenmech
10-15-2006 20:23:15
If you have removed the drive disc that was pressed on the crank. You then need to remove the 4 bolts that hold on the clutch fork and pulley brake directly in front of the pulley. Remove that assembly and your pulley will come off. Salvage yard or maybe on E-bay for the bolt. Good luck. Ron Mn.
Jackie Bieghler
10-17-2006 19:20:43
 Re: 1950 John Deere A in reply to greenmech, 10-15-2006 20:23:15
Do I really need to remove the pulley brake assembly to remove the pulley wheel? Shouldn't the pulley slide off of the crankshaft without having to remove the brake assembly? I also need to find some good parts resources for the tractor. Any suggestions?
greenmech
10-17-2006 20:51:15
 Re: 1950 John Deere A in reply to Jackie Bieghler, 10-17-2006 19:20:43
Yes the clutch fork and pulley brake assembly have to come off in order for the pulley to be removed. There are 4 bolts to take off,pull it out and your pulley will slide off. Ron Mn.
B-maniac
10-16-2006 12:16:50
If you don't have a service manual or other instructional manual,you really should not even be doing this. I'm assuming you don't because it tells you just what you are asking AND a lot more you NEED to know.
