Restoration & Repair Tips Board
57? co-op tractor
j k miller
10-20-2006 10:43:55
would like to find out where i can get parts for my co-op. i believe it is a 57 found numbers under starter T-9207X on left side rear axel has 10-9 and 4887x76. when i bought i was told it was a 57. have two speed tranny with 8 forward a two back. is a narrow wheel and has 38 inch on the back. is six volt system.has sat for last 15 years.i will need rims,rights rear center, front grills and many other parts. also would like to find books on it. will be slow rebuild .also will need to find right paint numbers.it there any co-op clubs in northwest penna. any help in this tractor info will be welcomed.
J. Schwiebert.
10-21-2006 16:39:19
 Re: 57? co-op tractor in reply to j k miller, 10-20-2006 10:43:55
There should be a serial number and the model number stamped in the frame on the engine's distributor side. It sounds to me that you are trying to describe a Cockshutt 30 because of the 8 speeds. It is older than 1957. J.
Bob
10-22-2006 23:41:55
 Any ideas about this Co-op? in reply to J. Schwiebert., 10-21-2006 16:39:19
Don't fret about the odd operator's platform, with the steering wheel at the back. It was "farmerized"... reversed, with a loader mounted at the back.
The faded decals on the hood say "Co-op".
Any idea where the model and serial #'s would be, and which manufacturer made this series for the Co-ops?
Third Party Image
Third Party Image
Third Party Image
rusty tractors
10-24-2006 19:02:55
 Re: Any ideas about this Co-op? in reply to Bob, 10-22-2006 23:41:55
That appears to be a CO-OP NO.2. The model and serial # were on a plate that was mounted under the instrument panel. Some one must have removed it when it was "farmerized". They were manufactured in the late 1940's and early 1950's. If I remember right they were manufactured in the Minneapolis-St Paul, Minnesota area and were mostly wheatland models. I do have some manuals of the NO.3 which was a little larger tractor which used basically the same design.
