Restoration & Repair Tips Board
8N Brake Drum Specs
Jim JAG
10-23-2006 15:48:21
Does anyone out there know minimum thickness for 8N brake drums? or where I can find the specs?
souNdguy
10-24-2006 07:19:42
 Re: 8N Brake Drum Specs in reply to Jim JAG, 10-23-2006 15:48:21
Remember.. this isn't an auto that must pass a dot inspection.
As long as there is enough meat ont he drum to keep it from distorting under break pressure, and the ID is sufficient to ensure good break contact, even when adjusted out with slightly worn shoes.. you should be good to go.
Cars go 30-40-50-60 mph... a brake drum cracking and locking up on te interstate would be bad. Ont he other hand, your 4mph stroll thru the pasture would be a bit less dramatic i fthe rear brakes locke dup due to a bad drum..
Soundguy
