Restoration & Repair Tips Board
Ford 1700 Hydraulics
RJ ROELLIG
10-29-2006 13:44:20
I changed the fluid and replaced the strainer-filter in the differential housing. To do so I had to remove the suction pipe. Everything went back together ok, but now lift and loader are dead. I suspect entrapped air, but have no bleed port. I can see the fluid moving in the sump through the fill hole. It has mucho air. Opening or closing the flow control valve has no effect. Any tricks or suggestions appreciated.
