Restoration & Repair Tips Board
48A Ring Gaps?
Sam S.
11-02-2006 05:14:18
The Manuals say the "Compression Ring End Gap" should be 0.039" - 0.053" and the "Oil Ring End Gap should be 0.028" - 0.040". These measurements would be installed in the cylinder and are the dimension between the ends of the Rings, right?
Where I am not as sure is the "Suggested Maximum Ring Side Clearance"? Spec. is 0.005" for the Compression Ring and 0.004" for the oil ring.
Question is, what exactly is meant by "Ring Side Clearance"?
Thanks for any help,
Sam
Bob
11-02-2006 05:30:38
 Re: 48A Ring Gaps? in reply to Sam S., 11-02-2006 05:14:18
To measure side clearance, slip a feeler gauge in between the ring and the wall of the groove, and see what'cha got.
Sam S.
11-02-2006 08:15:57
 Re: 48A Ring Gaps? in reply to Bob, 11-02-2006 05:30:38
Hey Bob,
So this is the differencein the width of the ring thickness and the groove in the piston that it fits into? Assures a good fit, yet no binding of the ring when installed.
Does that make sense what I said?
Thanks,
Sam
Bob
11-02-2006 08:34:40
 Re: 48A Ring Gaps? in reply to Sam S., 11-02-2006 08:15:57
You got it. Check out the ring fitting tips at the site below:
