9N wont spark
Scott M
03-19-2002 17:13:32
I have a front mount distributor 1945 9N tractor that was converted to 12volt. Tractor ran fine and would occasionally overheat after a couple hours of use. Ran fine until the other day and then no spark at all. Found out the rotor inside distributor was bad. Bought new rotor and decided to replace points, condensor and coil while I was at it. Also replaced indash resistor (found out it was bad)Now I get 12v clear through coil and through distributor until I get to the rotor. The mount where the rotor sits only gets about 2-3 volts. ( I took the distributor and coil off and grounded them to the frame and tested it with the key on and the distributor cap and plug wires off.) Could my condensor possibly be grounding out the distributor? I have tested for continuity through the distributor with it off and everything checks out fine. I just can't figure this one out. Been working on it every night. Thanks
brian
06-27-2003 00:16:51
 Re: 9N wont spark in reply to Scott M, 03-19-2002 17:13:32
It was probally a 12 volt conversion, they they got cheap and kept the 6 volt coil on it with the 6 volt resister. I totally fried mine, put 12 volt on and it runs better than ever. Just can not get the axel seal to stop leaking on mmy brakes
Jim WI
03-20-2002 10:50:31
I'm not sure I understand your description of the problem but let's see what happens.
First, is the coil an OEM-style coil that mounts on top of the distributor? If not, we'll need a more detailed description of where you took the measurements.
Is the coil intended for a 12V or 6V system? (It could be either, we just need to know for sure.)
The following assumes an OEM-style coil:
With the points open, you should measure battery voltage at the input terminal on top of the coil (and at every earlier point).
On a 6V coil with the points closed, you should see between 2.5v and 4v when measuring between the input terminal on top of the coil and the engine block. If it's a 12V coil, you should see somewhere around 10V or so.
I don't understand what you mean when you say there is 2-3 volts at "the mount where the rotor sits".
