Restoration & Repair Tips Board
Cleaning Carbon Build up..
Mark/Ks
11-27-2006 14:25:19
Just wondering if any of you guys have good ideas to clean off carbon from pistons, valves, and heads???? I know I car wire brush them, but I was looking for a chemical that might clean them up.. thanks...
NE IA Dave
12-13-2006 20:15:54
 Re: Cleaning Carbon Build up.. in reply to Mark/Ks, 11-27-2006 14:25:19
Starting fluiid
the tractor vet
11-28-2006 20:36:18
If ya want to clean old pistons up get yourself some Mr. clean or Janitor in a drum and a steel five gallon bucket put about three and a half to four gallons of water in it and dump two bottels in the water then heat the water and keep it hot like 200 degrees and boli some piston soup and in a couple hours the carbon will come off with a littel stiff bristel brush and a old broken piston ring to get into the ring grooves then let them dry and your good to go. Try it you'll like it. Oh yea do it outside because it will SMELL REAL BAD.
Josh in Pa
11-28-2006 08:34:23
I used a broken ring to clean the grooves, and scotch brite pad and motor oil to clean the rest of it. Came out looking good.
Josh
msb
11-27-2006 20:33:23
An ordinary carbon and gasket scraper does just fine so long as you don't gouge the piston.An old piston ring also does a fine job.
