Restoration & Repair Tips Board
Dry Sleeves
VOLfarmall
12-01-2006 07:25:05
I have a M farmall with 1 cylinder with a crack in it, the crack is in the block about 3 in. long ,what can I use to make sure this seals when I install the new sleeve thanks for help Jim
John Shipley
05-02-2007 15:13:17
 Re: Dry Sleeves in reply to VOLfarmall, 12-01-2006 07:25:05
Hi Guys...sorry to interrupt your discussion but I have question about sleeves in an M engine and I would like to know if you all would be willing to consider my question...I appreciate any help I can get.
Richard H.
12-01-2006 12:03:33
I am not sure what type loctite it is for sure but there is a product for that if you are talking hair-line crack. Most times the bore is already to thin for more boring and I am not to sure what good it would do if the crack is there. I use Red loctite and have not had a problem, just make sure the crack is really clean before applying.
Richard
Rustyfarmall
12-01-2006 07:33:52
The only way to fix it is to take the bare block to a machine shop. He will bore out that damaged cylinder, install a repair sleeve, and then bore the repair sleeve to accept the new sleeve you have. Anything else you do is just a gamble and you will be doing it all over again in just a short time. It will be much less expensive to do it right the first time.
