Restoration & Repair Tips Board
Carbon removal from piston rings.
Ray in mi.
12-08-2006 15:21:51
I purchased a John Deere industrial tractor,( 3 cyl.gas), and discovered that the #2 cylinder spark plug wire was so corroded,(green corrosion), that the cylinder was not firing, I don't know how long it has been this way,and I assume the piston rings are heavily carboned, causing my engine to use oil, (1/4 qt. in 2 to 3 hrs. use). Any one know of a way to clean the carbon from those rings, using a chemical additive? I replaced the wire,spark plugs, and dist. cap, of course. Thanks, Ray
NE IA Dave
12-13-2006 19:50:21
 Re: Carbon removal from piston rings. in reply to Ray in mi., 12-08-2006 15:21:51
Please see above thread on carbon removal by (NE IA DAVE)
djm75
12-10-2006 04:25:12
essential lube best stuff in the world if you can find it.
Ray in mi.
12-08-2006 17:20:07
Thanks, Richard, but I did check compression, all cylinders checked out within 5 p.s.i. of each other, but I feel I am getting some blow-by, due to the rings not giving the proper "seal", when engine is in operation.-Ray
old
12-08-2006 17:48:09
 Re: Carbon removal from piston rings. in reply to Ray in mi., 12-08-2006 17:20:07
Couple things you can do. Put a little tranny fluid in each cylinder. Also put a little in the oil and the gas. About a pint in the oil if a 5 QT. system and about a QT. in 10 gallions of gas. Doing that will clean the rings, valve, and the carbon. Cheaper then MMO and works as good.
Ray in Mi.
12-09-2006 05:44:52
 Re: Carbon removal from piston rings. in reply to old, 12-08-2006 17:48:09
Thanks, Hobby Farm, I will give the tranny fluid a try. ray.
Richard H.
12-08-2006 16:25:00
Ray about the only way you will know what is up with it is to run a compression test. Problem is if the engine went a while that way that cyd probably is "washed Out". All gas, no oil. Just my 2 cents, Richard
old art
12-15-2006 16:01:27
 Re: Carbon removal from piston rings. in reply to Richard H., 12-08-2006 16:25:00
now that you got it fireing on all take it out and work it hard get it good an warm not over heated and keep going for an hour or so it will clean out a lot of that carbon watch it colse though.
