Restoration & Repair Tips Board
1066 pto
Chad from Michi
12-10-2006 17:26:29
I have an International 1066 with a single pto that is 1000 rpm. I was wondering if it can be converted to 540 and what it would take?
fred eagerton jr.
05-09-2007 20:28:13
 Re: 1066 pto in reply to Chad from Michigan, 12-10-2006 17:26:29
if you use the tractor a good bit, by a dual pto from a junk yard. be sure to se if they will let you turn in the one you have for a "core charge", i did this, got one for 400$, works perfect, cut at least 2000acres with my 1466 with no problems pulling a 20ft. bushhog
the tractor vet
12-10-2006 18:23:04
Well yes it can be , but with what ya need to do it and the cost of the parts you are way ahead of the game to go and get a complet unit and install it . As you will need a rear cover the gear a 540 shaft plus bearings and seals . Now if ya go to your friendly loacl Case I H dealer to price the parts make sure ya take along your NITRO pills you'll need them.
