Restoration & Repair Tips Board
CASE 1030 PTO PROBLEMS
JAMES NELSON
12-14-2006 02:07:55
I was wondering if anyone knows if the pto are adjustable or not? The problem I am having when you put the pto under load it sometimes turns and sometimes it does not. It stops and jerks back and forth and it will turn freely when not under load. It has happened to me two times once with the baler and once with the manure speader. I have check the oil and it is good. I want a little more iformation before I tear into it. I would hate to rebuilt the pto if I don't have too.
Eldo case
12-14-2006 09:06:00
 Re: CASE 1030 PTO PROBLEMS in reply to JAMES NELSON, 12-14-2006 02:07:55
Yes it will adjust. DON"T LET IT SLIP!!! It will warp the clutch plates. In fact it may already have done that because it runs when shut off. It should have a real good snap when adjusted correct.
bob Ro
12-14-2006 07:00:39
James there is a plate on right side of tranny that you remove and amke a slotted tool to work with. I think you turn to left to ighten should be just so it snaps in. I found the information at dealer and at the time he gave me a copy.I have to do mine again good luck
