Restoration & Repair Tips Board
Adhesive remover
Mike S
12-16-2006 09:31:02
Bought a truck that has stick on lettering that you can remove with a heat gun. But after removing the lettering, there is still some adhesive residue. Any suggestions on what to use to remove that residue without damaging the paint? I am thinking MEK or acetone would hurt the paint.
Craig in MO
12-21-2006 11:29:44
 Re: Adhesive remover in reply to Mike S, 12-16-2006 09:31:02
GOOF-OFF will take it off, should be available at the grocery store with the other cleaning products
Stumpalump
12-20-2006 14:34:24
Gasoline
glennster
12-17-2006 16:00:34
at the body shop we use a rubber wheel on an air grinder, then follow up with a wax and grease remover like prep sol or final wash. stop by a body shop supply store ask them for the wheel to remove pinstripes. its about 4 1/2 inches in diameter,about 1/2 inch thick, tan in color and is looks like a pencil eraser. it takes stripes and decals off real fast and doesnt damage the paint.
RustyFarmall
12-17-2006 04:45:43
Plain ol' rubbing alcohol. Just pour it onto a soft cloth or even a paper towel and start gently rubbing. that residue will come right off and will not harm the paint. I learned this trick way back in 1970 when it was my job to clean up the used cars and trucks at the local Ford dealership.
banjo
12-16-2006 23:37:53
might try Goof-Off also. read the contents first to see what warnings it may have for paint.
Michael Price
12-16-2006 20:17:45
Go to the hardware store and by the glue they should have some stuff called goo gone, it works great. It wont hurt the paint either.
edwin burgess
12-16-2006 11:06:29
try WD40 its supposed to remove glue residues
Bob
12-16-2006 10:30:13
Try the link below:
Mike S
12-16-2006 12:32:04
 Re: Adhesive remover in reply to Bob, 12-16-2006 10:30:13
WD40 did not work, but this 3M stuff looks promising. Think an autoparts house would have it? or some speciality store that caters to the car painting folks?
