Restoration & Repair Tips Board
2910 Ford farm tractor
black60church
12-22-2006 15:59:24
I have a 2910 Ford farm tractor and the lift will not raise. I just bought the tractor. I knew the lift would not work. the fuid is real milky looking. do you have any suggestions. thanks
Weldin Man
12-22-2006 17:48:21
 Re: 2910 Ford farm tractor in reply to black60church, 12-22-2006 15:59:24
Does your tractor have the pump mounted on the flywheel housing with the filter on the pump or the pump inside the center housing with the the filter under the left running board? Either way if the oil is milkey, it and the filter needs to be changed,if the tractor has been run for some time with water in the pump could be damaged. Does the tractor have IPTO, Does it work? The Pump suction strainer could be totally plugged and the pump is starving for oil.If it is you will need to pull the round covers from the sides and try to flush out the housing and clean the strainer. Depending on which pump you have the lift cover may have to come off or the pump pulled out of the housing.
black60church
12-23-2006 01:09:36
 Re: 2910 Ford farm tractor in reply to Weldin Man, 12-22-2006 17:48:21
the pump is mounted on the motor. i have to look and see where filter is. the pto is not independent and it works.
