Restoration & Repair Tips Board
JD 4020 lift arms
david ferrell
12-30-2006 11:51:33
Any ideas on removing the adj. lift link locks out of the lower lift arms on a 1972 4020? The tabs are broken off and there is no way to drive them out from the bottom with the link ends still in the arm.
JMS/MN
12-30-2006 17:07:46
 Re: JD 4020 lift arms in reply to david ferrell, 12-30-2006 11:51:33
Try shorting out a welding rod- maybe at lower than normal setting for the rod- to the spring-loaded pin. Then pull up on the rod. If the pin is broken off flush- try welding a nut to it, and pull it up with a vise-grip.
