Restoration & Repair Tips Board
John Deere 3141 1986 Gearbox
Clive Pridham
12-31-2006 01:34:25
I have a John Deere 1986 3141(believe to be) tractor, oil passing from gearbox through spicket housing not clutch spicket but pressure plate spicket. Is this simple to remove and replace once the tractoe is split or can it be done from underneath the inspection plate at the bottom of the gearbox.
Would be greatful for any assistance you could offer.
Happy New Year
HTR
01-01-2007 15:42:40
 Re: John Deere 3141 1986 Gearbox in reply to Clive Pridham, 12-31-2006 01:34:25
Well, I don't know what a 3141 is, or a spicket is. I did a little search, and found they are a Mannheim style tractor with a Perkins engine. I don't think you can repair any oil leak, into the clutch housing, without splitting the tractor between the clutch housing and the transmission housing.
I did not know John Deere ever built a tractor with a Perkins engine. Where, when, were the built, and where were they sold?
They appear to be, may be, a 2955 with a Perkins engine. Looks like the 3641 has the same six cylinder Perkins engine.
