Restoration & Repair Tips Board
9n oil pressure
Ray Hart
01-04-2007 05:16:56
I recently bought a 9n, when at an idle oil pressure is good but when you increase throttle oil pressure goes away. I took out the drain plug and found that the cup on the end of the pickup tube was gone and the tube was either bent or fabricated to reach the bottom of the pan, the tube size is abought half inch, any thoughts? thanks.
old
01-04-2007 10:36:22
 Re: 9n oil pressure in reply to Ray Hart, 01-04-2007 05:16:56
I'm guessing the oil level is where it should be and it has the correct dip stick right?? If so then you may have a cracked oil pick up tube and at the higher RPM its sucking to much air and you loose oil preassure because of it. I would drop the oil pan and have a look see
