Restoration & Repair Tips Board
gasket material
Chief 83
01-04-2007 11:14:02
I have pulled the top off my transmission and need to make a new gaskets that will sandwich the hydraulic tank bottom between the transmission cover and the actual transmission case. These are large gaskets approx. 12" wide by 3' long. Various thinknesses of gasket material are available. I'm thinking at least a medium thickness or should I go with the really thick stuff?
TimV
01-04-2007 13:11:09
 Re: gasket material in reply to Chief 83, 01-04-2007 11:14:02
Chief: There's a few considerations here: first and foremost, as a rule of thumb, you should use the thinnest gasket possible, as it will provide the best seal. However, if the flanges are out of flat, the surface you're sealing has a lot of deflection or poor clamp load, or if there's movement in the flanges (especially under load), you may need to step up in thickness a bit. A typical gasket thickness for this type of application would be in the neighborhood of 1/32" to 1/16" thick. Also make sure that the material you're using can stand up to hydraulic fluid or transmission fluid--many cheap grades cannot.
