Restoration & Repair Tips Board
2670 Case Question,s
Kirk in kansas,
01-08-2007 05:31:34
I see a little bit of water dripping from blower
vent,s in cab of my 2670 Case
I see it after a rain, or sometime,s if it,s moist,
Could this be the A/C system on top of cab?
Cause i see it,s been sealed with this grosse looking silicon goop, and whoever did it, did a lousy job,
John saeli in New York, maybe you could help ok, it,s kirk,
I need help on this,
showcrop
01-12-2007 17:19:53
 Re: 2670 Case Question,s in reply to Kirk in kansas,, 01-08-2007 05:31:34
I have found that it's worthwhile to take the roof access panel off about every other year and clean out the condensate pan or the drains will plug and then it drips like yours is
JMS/MN
01-08-2007 08:40:33
If it drips after a rain, likely the top unit is not sealed properly to the cab roof. Dripping after using the A/C, check the rubber tubes coming out underneath the cab- they drain the condensate pan. Should be a drain on each side of the cab. They plug with field dust.
