Restoration & Repair Tips Board
CUB oil seal
Jim Kuntz
01-09-2007 12:18:15
What is the procedure for replacing the crank front seal on IHC CUB ? THX
glennster
01-10-2007 07:27:48
 Re: CUB oil seal in reply to Jim Kuntz, 01-09-2007 12:18:15
i replaced the crank seal on my cub a while back. you need to remove the front of the tractor, ie hood, radiator and front steering bolster asem. use a puller to remove the front pulley, the seal pops out to the front. i bought my seal from case i-h, it comes with a speedy sleeve to put on the front pulley to repair the wear surface, you more than likely have a groove cut in it. get a new gasket for the bottom of the radiator too. the front end is cumbersome, be careful so you dont drop it. to remove the steering shaft from the front end, remove the two bolts at the base of the shaft, it will turn out easily.
