Restoration & Repair Tips Board
Farmall Super M -- Live Hyd. Reservoir Help Needed
Mark Ollila
01-17-2007 16:28:27
I'll try this restoration forum as I've received no response on the Farmall/IHC forum. I'm looking for a picture, drawing or a good description on how the Farmall Super M 'live' hydraulic reservoir mounts on the cover of the rear frame under the fuel tank. I have the reservoir support plate and the two spacers for the plate. I've figured out where the rear two holes of the support plate go. What is not clear to me is how the two spacers and their bolts mount to the frame cover. This is a mid-1953 Louisville tractor (s.n. SM-5056xx L) that appears to have been originally built with the battery-box under the seat and a counter-shaft hydraulic unit. The rear frame cover casting date is for 1953. Thanks in advance. Mark
Fred F
01-17-2007 16:51:46
 Re: Farmall Super M -- Live Hyd. Reservoir Help Ne in reply to Mark Ollila, 01-17-2007 16:28:27
Hi I have a hyd. reservoir unit from a S.M.T.A. i f it helps
Mark Ollila
01-17-2007 17:30:22
 Re: Farmall Super M -- Live Hyd. Reservoir Help Ne in reply to Fred F, 01-17-2007 16:51:46
Fred, Thanks for the feed back. The rear frame cover is different between a SM and SMTA. Regardless of that, how is the support plate for the reservoir attached to your frame cover? I'm assuming you have a tractor as well as the reservoir. -- Mark
D Slater
01-17-2007 19:38:14
 Re: Farmall Super M -- Live Hyd. Reservoir Help Ne in reply to Mark Ollila, 01-17-2007 17:30:22
Made a answer on farmall board. One thing not clear, is the battery located under seat at present time? If its under tank the front holes for plate mounting are located where battery box hold down strap goes. SM and SMTA frame covers are same size. If casting # on the cover you have ends with R3 its same # as MTA.
Mark Ollila
01-21-2007 17:02:26
 Re: Farmall Super M -- Live Hyd. Reservoir Help Ne in reply to D Slater, 01-17-2007 19:38:14
D Slater, I found the two holes on the rear frame cover. They were plugged with dirt and paint. Thanks again for the help. -- Mark
Mark Ollila
01-18-2007 20:58:05
D Stater, Thanks for the info. The battery is currently under the seat. I checked the frame cover part numbers and they are the same for the SM and SMTA. I will look over my frame cover more carefully for the two holes for the place where the support plate spacer's fit. Maybe they were plugged deliberately, or plugged otherwise. -- Mark
