Restoration & Repair Tips Board
Cockshutt 30 Stuck Engine
Jayne
01-20-2007 08:07:19
My husband pulled the engine on our 1954 Cockshutt and replaced the rear main seal. When he went to engage the starter it turned over several times it seized up. He did prime it and it had good oil pressure. Pulled the starter, not the problem. Tractor had sat many years..before pulling the engine again what could we check? (Won't crank forward or backwards)...
J Schwiebert
01-21-2007 19:41:28
 Re: Cockshutt 30 Stuck Engine in reply to Jayne, 01-20-2007 08:07:19
Are you talking the rear seal in that plate? Did the engine turn over before you put the rear main seal in? Please explain a little more. J.
jayne
01-22-2007 16:36:18
 Re: Cockshutt 30 Stuck Engine in reply to J Schwiebert, 01-21-2007 19:41:28
I would like to share photo of the head and manifold..how do you attach a photo?
Dave Sherburne NY
01-29-2007 12:43:29
 Re: Cockshutt 30 Stuck Engine in reply to jayne, 01-22-2007 16:36:18
Actually, posting pictures is not too hard. First you go to GALLERIES on the left of the page, select a Category like TRACTOR PHOTOS click on itj Under the red line, select ADD YOUR PHOTO fill out the form, Click on NEXT STEP Then select BROWSE which will browse your computer for the picture you want to upload to Yesterdays Tractors ITS good to know ahead of time the identifier for the photo you want to load. After you have the u r l for the photo, click on SUBMIT and wait while the photo from your computer goes around the world to the YT website. then click on SUBMIT THIS PICTURE and the photo will go to the TRACTOR PHOTOS GALLERY. Then click on TRACTOR PHOTOS on the left of the page. your photo should be at the top of the list Then you RIGHT CLICK on your photo in the gallery, and select COPY IMAGE LOCATION then when you post your reply, select the OPTIONAL IMAGE U R L box at the bottom, right click, and select PASTE. When you preview you reply , the picture will be there, and you submit your post. If you want bigger pictures, try this Link //www.kountrylife.com/cgi-bin/viewit.cgi bd forum th 337749
Jayne
01-22-2007 16:08:49
Yes, the rear seal. We just solved the mystery. I will try to post a photo. It"s amazing where mice can hide grain....
old
01-20-2007 08:15:13
Sounds like the cylinders where dry and caused it ti lock up. I would fill the cylinders with tranny fluid and let it sit a few days and see what happens before pulling the engine again.
Jayne
01-20-2007 08:20:54
 Re: Cockshutt 30 Stuck Engine in reply to old, 01-20-2007 08:15:13
Thank you. I have some Marvel Mystery Oil on hand. Will give it a try
