Restoration & Repair Tips Board
Farmall H Tires
m olivo
01-21-2007 16:28:29
I have no experience as a tractor mechanic, but I want to replace the front tires on my Farmall H. Can anyone help me with the procedure or recommend a reference source ???
Thanks in advance,
marco olivo
GeneMO
01-29-2007 17:15:11
 Re: Farmall H Tires in reply to m olivo, 01-21-2007 16:28:29
If you need to know how to remove the rim from the wheel, you remove the 3 bolts holding the rim to the wheel. Then it is kinda like a puzzle getting everything at the right angle so the rim with tire will come off. I run one wheel of the narrow front end tractors up on a 4x6 wooden block, this gives you the space you need to worm the rim off. Then remove the tire like the other posts say. I also recommend taking it to a tire store. Your time is worth more than you can save by doing it yourself.
Gene
GeneMO
01-29-2007 17:21:43
 Re: Farmall H Tires in reply to GeneMO, 01-29-2007 17:15:11
I forgot to mention something. With the one tire up on the 4x6, and the tractor safely chocked so it"s safe, I set down faciing the tire and scoot forewards till the tire is between my legs, then you just have to muscle it off. Generally lift it back a little then up on one side then kinda turn it crossways and it will come right over the wheel. It takes a little practice. Doing it outside, at night, in the rain or snow is not recommended!
Gene
souNdguy
01-22-2007 06:36:17
I agree with the other poster.
Samll fronts can be dismounted and remounted using a couple tire irons and spoons.. etc.
If ya can't break the bead.. drive over it with your truck.. etc.
Put a spoon in and pry the bead away fromthe rim.. slip another in and work it away and go around.. like a can opener. once one side is off.. start the other side.. should be easier getting the 2nd side over the rim as it will be setting in the trough of the rim and will be easy to get the irons under.
If you plan on re-using the tube.. be carefull. I seldom reuse them unless they are almost new... I do save them for emergencies though, if they still hold air.
After old casing off..check the rim for bents from demounting.. hammer back into shape if needed, then clean up the rim if there is any rust.. wire wheel, and paint.. let cure.. slip new casing old like old one came off.. once first side is on.. slip tube in.. have a valve fisshing tool on hand to get the valve out the rim when you are ready for it.
Vegi-based lubes and tire 'soap' can be used.. but no petro oils or silicones.
Finish getting the other sid eof the tire on.. and fish the valve stem.. and air her up. You may see directions on the tube box or tire casing telling you how much you can overpressure to get the bead seated... then of course.. reduce to normal operating pressure.
I did this last on my 2n.. took about 30 mins per tire.. Honestly.. i won't ever do it again.. My local tire store charges 10 bucks to do it in 2 minutes while I watch...seems to be way easier that way...
Soundguy
Jason Mortzheim
01-21-2007 17:40:05
I have not tried myself but here is a link:
Link
For the small front tires your standard auto shop can do it as well. If you try it yourself let me know how you make out.
