Restoration & Repair Tips Board
How can I clean up a serial number so it can be re
seebug - PA
01-25-2007 18:51:20
The serial number on an Allis B is very hard to read. It looks like the numbers are either worn or never stamped into the housing clean. How can I clean off the serial number so it can be read without destroying it in the process??
old
01-25-2007 19:42:49
 Re: How can I clean up a serial number so it can b in reply to seebug - PA, 01-25-2007 18:51:20
A good carb cleaner and a rag. Spray it then wipe it then spray it again till you can see them.
RustyFarmall
01-26-2007 05:26:52
 Re: How can I clean up a serial number so it can b in reply to old, 01-25-2007 19:42:49
A word of warning, carb cleaner will also remove paint.
old
01-26-2007 08:59:12
 Re: How can I clean up a serial number so it can b in reply to RustyFarmall, 01-26-2007 05:26:52
Yep thats why it works well on the numbers on something like the allis tractors. Now do that on some other brands and it can remove the number along with the paint
