Restoration & Repair Tips Board
6-8 coats of paint-removal
wayne2
01-26-2007 20:47:48
I took a small -up to cup of gas and oil in shallow pan lit it off and set fender-etc over it and a little wire brush work wala-have bar of pumice soap ready when your done. LOL Wayne
F-I-T
02-08-2007 13:52:50
 Re: 6-8 coats of paint-removal in reply to wayne2, 01-26-2007 20:47:48
I sure favor electrolysis. I have used it for several years now, and I don't fire up my sand blaster anymore. I have an article that I wrote for a magazine a few years back posted on my website, along with a few pictures. It might be helpful.
BTW, it will work on ANY color tractor!
Frank Website: www.fboerger.com
vette
01-28-2007 13:56:50
Get you a can of aircraft stripper from your local wal-mart or tractor supply stor. Brush it on, wait a few minutes for it to bubble up and scrape it off. be sure to wear a good pair of rubber gloves and Goggles . It,s pretty caustic
RustyFarmall
01-26-2007 22:12:42
A heat gun and a scraper worked very well to remove 18 layers of paint with virtually no fire hazard.
rustyj14
02-08-2007 09:02:42
 Re: 6-8 coats of paint-removal in reply to RustyFarmall, 01-26-2007 22:12:42
Aircraft Stripper won't buckle the metal, is much safer than using fire in a shop, and is available at most auto body/paint supply stores, and sells under that name! I've used it on jobs with 4 or more paint coats on the machine, and it doesn't take long to get the paint softened enough to just lightly scrape it off with a wide putty knife! Then a water wash and clean up. And a wash with Pre-Kleano, or enamel reducer.
DurangoCase
02-08-2007 10:24:17
 Re: 6-8 coats of paint-removal in reply to rustyj14, 02-08-2007 09:02:42
I've even seen Aircraft Stripper for sale at Home Depots and Checker Autos.
