Restoration & Repair Tips Board
8N Starting troubles
Damon
01-27-2007 08:22:56
I have a '52(?) 8N tractor that I am having trouble starting. I recently tuned it up, thinking that was the problem, but it hasn't helped. I also re-wired this past summer since mice had chewed the harness, but again, this didn't help. When I push the starter button, the engine cranks, but then it changes to almost a high pitched humming sound, with no more engine cranking. I stop pushing, then repeat, with the same results. The battery was replaced when I re-wired, so it's not the battery, either. The problem is worse since it has gotten colder, and now I can't start at all. At least during the summer it would eventually start! I'm wondering if anyone can help me with what the problem might be--I'm thinking starter, or maybe a carbourator re-build? Any help is appreciated! Thanks!
Bob
01-27-2007 08:38:24
 Re: 8N Starting troubles in reply to Damon, 01-27-2007 08:22:56
It sounds like your starter drive ("Bendix") is malfunctioning, and releasing before the engine starts.
The newer drives are called "positive", as they aren't supposed to release until the engine starts.
As with everything, there are good and bad ones of those, too, with some not-so-good imports around these days.
I wish I could tell you for sure where to pick up a GOOD unit nowadays.
Bob
01-27-2007 08:38:20
Damon
01-27-2007 11:19:48
 Re: 8N Starting troubles..to Bob in reply to Bob, 01-27-2007 08:38:20
Bob, what about THIS one:
Antique Tractor Parts and Related Items
Featured Product
For Model 9N, 2N, 8N (Ford) Starter, 6 Volt, With Drive - New Starter for 9N, 2N, 8N. 6 Volt.Complete starter - includes drive mechanism. Replaces OEM # 8N11001R. (Part No: 8N11001WD) $129.00 [Enlarge Picture] Call 800-853-2651 to Order
This is listed here on this site...is this what I need? Is it difficult to replace?
Thanks for your help!
Bob
01-27-2007 12:32:38
 Re: 8N Starting troubles..to Bob in reply to Damon, 01-27-2007 11:19:48
Damon,
Apparently, that is the complete starter.
If your starter MOTOR is working properly, you can just replace the "DRIVE" for about $30 to $40. This site has those, too.
I have to cut this short, as I have a family outing to attend to.
Go over the "N" forum and do an archive search for "Removing Starter", and "Replacing Starter Drive".
If you need more info, post back, and someone will help, or I will reply later.
Bob
01-27-2007 12:32:33
Damon,
