6 teardrop headlights
Chris C.
10-09-2001 21:38:46
If you want to keep the classic look of the old "guide lamp" style headlights but update to sealed beam, you can use a standard 5 3/4" headlight. Run a bead of RTV around the back of the bulb rim as a cushion and let dry. Then install the bulb and loosely install the band clamp.a circle of 1/4" tubing either clear vinyl or rubber will fit snugly around the circumference between the bulb outer rim and the clamp, then just tighten the clamp till everything is secure
