 Jim, As it seems you know about these things I'll pose my current power steering problem with our UTB 640DTC to you (and to the rest of the forum). Steering is erratic, the wheel feels 'bumpy' and it feels like I have to manually force the wheels in the direction I want them to be before the power steering comes in. With power off and the front wheels off the ground I can manually push the wheels (and the power steering cylinder) towards a left turn (pushing the piston into the steering cylinder). Also without power it is easy to turn the wheels in one direction using the steering wheel, but in the other direction I can rotate the steering wheel many times before the wheels turn. Once I've got them turning it works in both directions but as soon as I stop turning the wheel for a few seconds this 'freewheeling' effect sets in again. Looking at the hydraulic fluid I notice that it has some foam on top and seems to contain quite a bit of air bubbles. The tie rod ends are worn and need to be replaced, as does the ball joint at the frame end of the power steering cylinder. I will need to adjust the steering once I've replaced the tie rod ends and ball joint. As I have no service manual (do you? Can I copy it? Pretty please? I've been searching for one for more than 2 years now... :-) I have no data to go on... So if you (or anyone else who knows this model/series) can help me out I'd be much obliged. BTW, this tractor has fully hydraulic steering - no mechanical link between the wheel and the steering cylinder or front. Just the manual pump thing under the steering column. TIA//Frank
