Restoration & Repair Tips Board
John Deere B Fuel supply
Blake Partridge
02-05-2007 10:48:09
Can anyone out there tell me why my JD-B will not send fuel to the carberator when I dump the fuel bowl and tighten up the screw on the bottem of the fuel bowl? What do I need to do? My JD-B will not start,it allways starts. Can you HELP?
Gary in Ca.
02-22-2007 18:27:34
 Re: John Deere B Fuel supply in reply to Blake Partridge, 02-05-2007 10:48:09
Make sure you dont have an oil pressure opeerated fuel shut off valve, then check for fuel flow at the outlet side of the valve to make sure the shut off is not sticking and is working properly. Next check at the carb inlet to be sure the line isnt clogged. then ckeck the float and needle valve. Then check the ignition system.
old
02-05-2007 11:49:40
As Mike says that just normal and also isn't the no start problem. I would check for things like spark, and also check that you do in fact have a good flow of fuel to the carb. If the float is stuck and its up it will not let fuel in and that could be the problem
BLAKE P.
02-26-2007 05:46:14
 Re: John Deere B Fuel supply in reply to old, 02-05-2007 11:49:40
I FOUND THE PROBLEM. I HAD A BAD FLOAT AND NEEDLE AND SEAT. THANKS FOR YOUR HELP.
Mike M
02-05-2007 11:32:33
That just shows you the float needle is sealing.Open the drain on the bottom of the carb. and fuel should start to run into the fuelbowl. This really shouldn't effect starting after you do this as the carb. bowl is still full not letting any run in.
